1UZFE with manual swap, Vvti or not
Hey guys, im sure this has been talked about before but i might as well try and ask so please no hating, bashing, or flaming. I have tried searching many different ways and cant really find anything useful. Before i go on to what i am really looking for, i will tell you this; i will be making this into a track car. (NASA/time attack/hpde) My plan is to swap a r154 into a sc400 but im just not sure on if i should go vvti or not. my future plans are to get anywhere from 350-400 rwhp n/a, i will be building the motor, possibly going with a lextreme 2uz swap with 1uz heads as ive seen plenty of times before from other peoples builds on other forums.
So what i am trying to ask is should i go vvti or not, ive heard of issues being had trying to make that kind of power and people just "turn off" vvti because it becomes useless, but from my own theory why would you not want vvti, since it is technically like vtech you can gain much more power and torque if properly tuned. is there something im missing, is there a reason why people are not running vvti when going for crazy horsepower?
im sorry for any improper grammar/punctuation but it is 2:30am. thanks guys.
EDIT:also i will be adding cams to this build, i forgot about it when writing.
do you know what that cel is? i can do wiring, i might be able to figure a way around it. or i have some friends that can help me out with it. any other reasons why i shouldnt go vvti?
I think the general consencus is that the vvt-i 1uz has a lot of eletronics since its the newer engine, which makes it harder to tune. Not to mention weaker internals than the non-vvti.
But if you're building it ground up with stronger internals it seems like you have the know-how to get around most of the problems that keep everyone else from going this route.
Most of the other answers you're gonna get will say "why not just go 1 or 2J cuz theres a ton more aftermarket support for it, for easier and cheaper".
You can ask member spdrcr771 about his forte into modding the vvt-i 1uz, from the sounds of it he's regretting going that route because the amount of money he's spend on the barely 300whp hes been able to squeeze out of it, he could have had a 4-500whp 2J by now.
I'd say stick with the vvti motor. The main thing I been looking for are cams for the vvti motor. I don't know if they are the same or not. And also fuel management. I read some where there were a couple of people having problems with the ems2? But it was vague.
pass1914
Performance & Maintenance
09-15-05 03:35 PM
