Going rich but only at 2K? SC4
Old 08-18-12, 09:44 PM
ihiryu
ihiryu's Avatar
Default Going rich but only at 2K? SC4
I have no idea, but at 2K my car runs super rich, the gauge goes to 12:1, I'll adjust the SAFC to negative, then the gauge will go lean, then bounce back and forth until it goes to 12:1.
Anyone have any idea?
Old 08-18-12, 09:53 PM
xspsi6
xspsi6's Avatar
What year sc400? The ecu is most likely trying to fight the change from the afc.
Old 08-18-12, 10:26 PM
ihiryu
ihiryu's Avatar
92, nope cause it does it when the SAFC does it when it is zero also
Old 08-19-12, 09:23 AM
xspsi6
xspsi6's Avatar
And the air flow meter is set to Karmen? Take the afc out and jumper the brown wire which will set it back to stock and eliminate the afc as potentially part of the problem.
Old 08-19-12, 09:45 AM
Vrank
Vrank's Avatar
ecu going bad?
Old 08-19-12, 12:18 PM
ihiryu
ihiryu's Avatar
AFC has been hooked up over five years. Yes it's set to KMV. I'll check the wire on the SAFC though, maybe it's come loose after all this time.
I also think it may be my ECU taking a poop finally though. Since it only does it at this RPM at cruise. It's fine if I got WOT at that RPM range
Old 08-21-12, 11:01 AM
ihiryu
ihiryu's Avatar
Well I replaced the ECU with another one, still the same thing. I'm starting to think maybe it's an o2 sensor.
I'm going to try to unplug them to see what the car does.
Old 08-21-12, 06:53 PM
ihiryu
ihiryu's Avatar
Unplugged O2 sensors, disconnected FMU all together. Nothing, no differences at all.
Old 08-23-12, 08:22 AM
ihiryu
ihiryu's Avatar
Replaced KMV sensor, found a vacuum leak, fixed it. Reset ECU, same thing.
p00rbob
03-03-13 12:55 AM
vwynn
Performance
34
04-18-12 05:30 AM
tpnotch420
07-29-08 04:59 AM
rlhsc400
SC- 1st Gen (1992-2000)
07-22-08 06:38 PM
Quick Reply: Going rich but only at 2K? SC4
