Brian Crower 1jz 264 camshaft results.
Very good info, I am in the market for some cams and I was told by someone, which is a motor builder, that the BC cams weren't good. I don't take anybody's word without evidence, so i was a bit skeptical, i think this proves it. just curious.
1. what is your application? street, road race, drift, drag?
2. how does the cams change the mid-range hp/tq?
Thanks
Thanks
I think the gains would be more impressive on a good single turbo set-up.
If there is a better option than BC I'd like to know what it is.
The stock twins can really only flow so much CFM. The power actually seems pretty reasonable for a car on stock twins with an auto trans.
Well I actually am running a single turbo Garrett GT35, aem ems v1, 850 injectors tial 44mvr, greddy intercooler. and all stock internals. I am competing in formula d pro ams so I am looking for a good mid range to high range power. at the moment my motor dogs out at under 3800 rpm so I know cams will help in that. just curious how much help and also want to know what the 1j community's consensus is on cams. I thought it was all about BC so this affirms that, just wondering if there is a better option.
i dont have a tune yet.
1JZ Single SC400
If you are wanting to potentially move forward to the S366, as I have, I would go with stage 2. The reason I say this, is that these yield on average 50 rwhp gain just by dropping these in. If you want to change your head gasket and increase the amount of boost pressure to meet your goals and then some, then go with stage 3. This requires the valves and so on also to be bought from BC. A definite tune will need to be in the works, just to start your car. The stage 3 also may allow the motor to rev to the moon, maybe 9K rpm or so, which what I read on the SF. I only wanted 500 plus to the wheels on pump and be safe with my setup. I didn't want to keep pushing it until I was tired of the 522 I have now, which I am very pleased with.
I know I've posted this a few times but this ?? keeps coming up so I post this link again.
Enjoy!
http://www.youtube.com/watch?v=yZmnV0M3kHA
Enjoy!
You will need to do springs with a 272 and I highly recommend shimless buckets.
I am just not sure how lazy the s366 with the 272's are going to be on the street but this will determine which way I go as far as the buckets go.
I have bc springs so they are good enough for the 272 cams but everything else I would like to leave stock as the budget for this build is out of control at this point
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Haha yea prius buckets are the shim less ones everybody uses but I am still debating on going this way my self as I am looking for 500 on pump and 600+ on q16 all with a built auto.
I have bc springs so they are good enough for the 272 cams but everything else I would like to leave stock as the budget for this build is out of control at this point![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
We have been doing shimless buckets long before the Prius for the record.
