Exhaust leak help.
Old 08-29-12, 10:28 AM
birdmane
birdmane's Avatar
Default Exhaust leak help.
1999 Lexus Sc300.
-4 inch exhaust, single pipe, from the resonator back.
I had it installed at a shop, wasn't sure if it would fit. I told them to install it only if it would fit properly. I took it for an oil change and was able to get under it to inspect it.
Where the resonator meets the new pipe, im guessing its 2.5in resonator outlet to a 4 inch pipe, not ideal sizing, there is a leak at the top of it. You can feel it with your hand, but you cannot hear it while idling or driving.
I spoke to the shop and they are going to fix it, just wondering what the options are. Right now it has a real nice throaty/deep/low growl to it. Would removing the resonator make it a lot more whiny or unbearably loud?
Any info is appreciated.
Only crappy picture I have. Bottom right corner is where the leak is
Old 09-10-12, 07:09 AM
birdmane
birdmane's Avatar
Any help?
Thanks
Old 09-10-12, 08:14 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
I have an exhaust leak but I don't really care...it will deteriorate your cat's quicker I think...
Old 09-10-12, 09:02 AM
Ali SC3
Ali SC3's Avatar
why is there a 4" exhaust connected to a 2.5" resonator? loose the smaller resonator already.
there is no point to 4" piping it you have a 2.5" bottle neck. you would need like 3 step down adapters to weld that thing without leaking. they will put welds on welds, and one day it will crack. make it all the same size, and weld in a high flow cat if you have to. just my 2 cents.
Old 09-10-12, 09:17 AM
spoolxexo
spoolxexo's Avatar
Vband flanges, get em!
Old 09-10-12, 01:51 PM
birdmane
birdmane's Avatar
I like the sound of it now...how different will it be without the resonator?
moses0324
10-25-13 05:27 PM
Bradster
42
06-04-12 01:08 PM
BrittonJ85
15
05-26-10 03:46 PM
j0xxx
Performance
09-01-07 06:59 PM
mcelligott
03-18-03 05:26 PM
Quick Reply: Exhaust leak help.
