sc400 pcm in a sc300
Old 09-08-12, 12:34 PM
coreytat
coreytat's Avatar
Default sc400 pcm in a sc300
I recently purchased a sc400 1uzfe pcm and attempted to put it in my 1993 sc300 both are the same years every pin matched the only thing that was different was the ignition signal from the cams sensors / distributors on the 1uz uses pins 5,6,7. 5 is for left bank 6 is for the right bank 7 is rpm signal after i installed it got a code 15 ignition signal and a code 78 fuel pump ecu which is disabled in my car with 12v mod my stock pcm never gave me code 78 which along with the failed injector drivers is why im changing out the pcm plus a nice little burn spot on the board so back on topic in theory you should be able to splice into pin 7 on the e10 connector on the pcm and jump it to pin 6 and 5 . from there the ignitor should take over and it should run ........ should not for the faint at heart and i dont know if im going to attempt this or not but we will see how desperate I get to drive my car pimp the ruckus till it rains
Attached Thumbnails sc400 pcm in a sc300-diagram-1.jpg   sc400 pcm in a sc300-diagram2.jpg
Old 09-08-12, 03:31 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
SO, can you use ECM #2 to repair ECM #1 since they are pretty much identical, or at least follow the trace and try it one more time with the jumper in place?
Old 09-08-12, 04:29 PM
coreytat
coreytat's Avatar
im gonna try it first with the jumper wires first
mally99
11-03-16 07:26 AM
mally99
Maintenance
11-02-16 11:23 PM
VAgs430
SC- 1st Gen (1992-2000)
05-04-14 07:30 PM
GS300CMO
02-05-13 07:56 PM
t70 supra
12-04-10 09:24 AM
Quick Reply: sc400 pcm in a sc300
