car jerks forward and backward when driving
Old 11-12-12, 06:43 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Originally Posted by scott101
i got 2 sensors out of a 1992 sc300. one was on the throttle (TPS) I believe, and the other was on this secondary throttle thing inline before the actual throttle. Not sure what it is. Anyways, both the sensors look identical, have the same part number, but they have different white numbers on them. They also look slightly different to the TPS in my 1993 sc300. will they work? should I give it a try?
thanks
scott
will put up pictures and part numbers in a bit
You did get the real TPS out of the SC300. But you also got the Trac TPS as well. (Traction Control System). The Trac uses a TPS, it will always be to the left of the "real" TPS. If you don't have Traction Control, I don't think you will need it.
*(btw, I forget the site I purchased my TPS at, but I guess that doesn't matter anymore now that you have a TPS. )*
GL man...
Old 11-12-12, 12:14 PM
scott101
scott101's Avatar
GL man...
alright, thanks, Ill give the new one a try. is it plug and play or do I have to calibrate it like people were saying? and what does this require
thanks
scott
Old 11-12-12, 12:23 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Once you get the TPS in, it will require calibrating, (what I call it), that is, moving the TPS back and forth both ways slowly, with the car running. Find the spot of were the idle is perfect, or as perfect as you can it at the time. Not hard, just tedious.
Old 11-13-12, 07:05 PM
scott101
scott101's Avatar
sweet, very helpful, thanks
i will do this tomorrow
i forget which sensor is which, but i will look it up online
they both have part number 89452-33010, its the white numbers that are different.
thanks
scott
Attached Thumbnails car jerks forward and backward when driving-img_4684.jpg   car jerks forward and backward when driving-img_4686.jpg   car jerks forward and backward when driving-img_4688.jpg
Old 11-13-12, 08:21 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
You cannot put the trac TPS to were the primary TPS is on the throttle body. The trac TPS spins the opposite way. As long as you identify the Trac TPS, you will be good. That's the reason whenever I get both the trac and the primary TPS's at a junkyard, I put a scratch on the Trac TPS, just so I know. Let us know if replacing the TPS works.
Old 11-14-12, 12:24 PM
scott101
scott101's Avatar
ya, that makes sense, ya i figured that i the other sensor wouldnt work right. ill try to figure out which one is which
Old 11-14-12, 12:37 PM
scott101
scott101's Avatar
now that you said that, i think i should be able to figure out which is which by looking at the way that they spin or something
thanks for the info though
Old 11-16-12, 09:53 PM
scott101
scott101's Avatar
I tried one of them (they both spin the same way and look pretty identical), but the problem is still happening.
NOTE; it seems that the bucking happens when car heats up, it does not depend on wether or not it has been turned off and restarted (it does this now and before the new sensor)
ill try the other one tomorrow but I doubt thats it. Whats up next, the maf?
thanks
scott
Old 11-16-12, 10:00 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Next on the list; MAF!
Old 11-17-12, 10:31 AM
scott101
scott101's Avatar
will do, thanks. ill just go through the list, its gotta be some sensor or something
Old 11-17-12, 11:35 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
I was almost 100% sure that it was the TPS...I had the same symptoms and the TPS fixed it...If MAF does not fix the problem, (highly unlikely), than were gonna move on to the tranny mounts. GL
Old 11-18-12, 10:29 AM
scott101
scott101's Avatar
im pretty sure the MAF fixed it. i will drive some more today and double check but it did not act up yesterday, cold or warm, on the first start or after it was killed and restarted. seems to be working well
anyways, everyone was saying that with the TPS, it would be fine on the first start but only after restarting it would it begin to act up. in my case, it would act up just when it warmed up, it didnt have to be killed and restarted
thanks for all the help
-scott
Old 11-18-12, 10:42 AM
2JTsc300
2JTsc300's Avatar
told u man it was the MAF, glad i could help u out, lets us know of u need anything else
Old 11-18-12, 02:08 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Great! Glad the MAF fixed the problem. Unfortunately, with Lexus, any problem is hard to overcome if your not familiar with the car. But that is what makes a Lexus, a Lexus. GL to your further projects!
Old 11-18-12, 03:28 PM
scott101
scott101's Avatar
thanks for the help you guys. i drove it again for a while today and it was running well
Quick Reply: car jerks forward and backward when driving
