car jerks forward and backward when driving
#31
well, im back, unfortunately
what are the odds the maf I just put in went bad? it was used from the yard, but it seems fishy
I drove the car every day for about 10 days or so. then I took out the old drivers seat to put in my bucket seat. i welded the little tabs to the sliders in the car, finished the welds outside the car, and not I have a bucket seat
then I plugged the battery back in and it ran fine
but once it warmed up, same symptoms as before. jerking at 2500 rpms under acceleration and when in neutral, it occasional sounded like the motor was stumbling/hestitating. the rpms would drop about 200 and then recover over and over (this happened a couple times)
ill go try another maf, then repost my results here
thanks for all of the help you guys, I really appreciate it
-scott
-scott
#32
Here's how to test the MAF.
![](http://i87.photobucket.com/albums/k146/damoneydada/Screenshot2012-05-17at90602PM.png)
Didn't really wanna read everything, but have you set the TPS to spec? Next thing I would check would be the distributor, something to deal with ignition, like wires, spark plugs, coil packs and/or fuel injectors...
#34
ok, thanks, will do. doesnt help that my car wont even start now, starter motor spins but no spark I guess, Ill check that first, then see where Im at
thanks again for all the help, I appreciate it a ton, Ill report back where Im at after tomorrow
-scott
-scott
#35
So what it could be: Un-calibrated TPS, Fuel pump ECU, ECU, Fuel pump, MAF...????
Is there any CEL? If there is pull the codes to see what comes up.
Read through these threads. Don't start just replacing thing's you don't need to though.
https://www.clublexus.com/forums/sc-...en-dies-2.html
https://www.clublexus.com/forums/per...on-issues.html
#36
could the maf or tps alone prevent it from starting? or would those just cause bad running once it is running
not starting seems to me like it would me more like ignition coil or something like that
-scott
#37
Here is another thread to check out. https://www.clublexus.com/forums/per...-starting.html
Could be ignition coil as well.
Just test the MAF and see if it broke already. We'll go from there.
#38
i put in a different tps (I have a collection of them now) and adjusted it all the way counterclockwise, however, Im not sure if it is in the right way/adjusted properly, because anything other than maxed out counterclockwise and it doesnt run well, and too far clockwise the car will shut off. it ran fine tonight though
-scott
-scott
skyther
10-20-17 06:09 PM
Todd1225
Performance & Maintenance
16
08-15-09 09:12 PM
Todd1225
04-13-07 10:59 AM
