should i add a tranny cooler on single turbo 2jzgte
Old 09-17-12, 08:23 PM
sidwin
sidwin's Avatar
Default should i add a tranny cooler on single turbo 2jzgte
I'm taking the bumpers off to get painted soon and i was wondering should i add a tranny cooler? this is my first auto so do i simply add the tranny cooler to go after the stock tranny cooler or do i bypass the stock tranny cooler all together?
thanks,
sid
Old 09-17-12, 08:31 PM
blk&blu*j
blk&blu*j's Avatar
thanks,
sid
YES--------YES--------------AND YES Bypass the stock radiator trans cooler.
Old 09-17-12, 08:36 PM
SChema
SChema's Avatar
Any heat you can remove from the transmission fluid, the longer the trans could potentially last. Or you could go six-speed and remove the cooler and related parts altogether.
Old 09-18-12, 10:51 AM
sidwin
sidwin's Avatar
ok sounds good... bypass stocker and get bigger one..
now which bigger one, and where do you all buy them? any installation pictures?
Old 09-21-12, 07:05 PM
bryan767
bryan767's Avatar
whole heartedly agree, i ended up putting a third electric fan in front of my trans cooler for better off the line shifts
Old 09-21-12, 07:12 PM
Clean400
Clean400's Avatar
I bought this one.
B&M Transmission Cooler 70264
It's mounted on the front ride side of the bumper. It has it's own area away from the radiator all by itself. My installer did a good job. It's hard to take pics cause it's already installed.
Old 09-21-12, 08:16 PM
sidwin
sidwin's Avatar
thanks guys. i just dropped a hayden in there. damn thing is about 35% the size of my radiator
how much power do these aristo tranny take before the let go?
Old 09-21-12, 08:27 PM
xspsi6
xspsi6's Avatar
I would not bypass the stock cooler as that can cool faster than an external cooler so the proper way to do it would be to run an aftermarket after the stocker before it goes back to the trans so with that being said I run 3 coolers as this is how ATF speed told me to do it.... Stock in to a B&M super cooler with a fan then in to a tube and fin cooler for fast flow which is how the 1000+ whp supras with built autos do it.
Pics of the set up....
Old 09-21-12, 09:16 PM
bryan767
bryan767's Avatar
^ never really thought about that.
but what if the whole line was a cooler?
Old 09-21-12, 10:12 PM
xspsi6
xspsi6's Avatar
What do you mean by the whole line as a cooler?
Old 09-22-12, 06:46 AM
lexforlife
lexforlife's Avatar
agreed but with one major change , i would bypass lines going into bottom of stock rad , keeping the stock tranny lines cooling thru bottom of stock rad adds more heat to the rad for your fan to disperse and for the tranny fluid side of things , running the fluid thru the bottom of a hot radiator diminishes the ability of the radiator to actually cool the fluid correctly .. the initial design was intended for low hp usage.
Old 09-22-12, 08:15 AM
blk&blu*j
blk&blu*j's Avatar
gh
Plus alot of HP guys are running a aftermarket RAD which is not capable of passing trans through them.
Old 09-22-12, 08:29 AM
xspsi6
xspsi6's Avatar
Which is what I am going to do ^^ so I will be down to just the 2 coolers however I don't feel that losing the radiator cooler will be that big of an issue however I wish I had a way to keep it.
Old 09-22-12, 09:26 AM
blk&blu*j
blk&blu*j's Avatar
The benefits of the RAD portion of the cooler is virtually useless once single, the true benefits
will be recognized with a good quality cooler and a fan.
sidwin
09-21-12 07:10 PM
vdhkevo
Performance
06-22-09 01:13 PM
DIrEctQL
SC- 1st Gen (1992-2000)
07-22-02 07:12 PM
Quick Reply: should i add a tranny cooler on single turbo 2jzgte
