Na-T Crank Seal Issues
So i built my motor about 2 1/2 years ago. Wiseco Pistons, eagle rods, Titanium springs and retainers, stage 3 cams, and switched to the GTE oil pump in my Sc. At first (for some dumb reason) it didnt cross my mind that i would need to switch the crank seal to a GTE one from the stock GE. I blew out 2 or 3 GE crank seals before it hit me. soi would say about a year ago i put a GTE crank seal in her and it held up nicely for about 7-8 months. then the car began leaking oil from the timing cover down the oil pan. I knew it and blown another seal.
I daily drive/ rail it at 12psi, my defi oil pressure gauge reads at about 120-141psi (in full boost).
Does anyone have any suggestions, or have this issue as well? please help me out lol
it could have something to do with your gte oil pump, or you may have crank case evacuation issues.
I have read the gte pumps flow more than the ge to make up for the oil squirters.
Since you don't have any oil squirters the gte pump may actually be a bad thing.
do you have a catch can setup, if it is too restrictive and you normally get blowby, that could be part of the reason as well.
read this and you will see about the oil pumps, it probably is flowing too much and the gte seal has a few differences (edit: only vvti) .
I know these are vvti, but there are similar differences in the non vvti versions.
match oil pump to engine, if you need a GE oil pump with a crank sensor fitting, just get a 96+ GE oil pump that has the fitting like the gte.
These guys are saying past 100 psi the pump is in bypass mode, sounds like your getting way too much psi.
http://my.is/forums/f114/tech-info-d...l-pump-437894/
