Can I use evo 8 560cc injectors?
Friend just gave me a set of six 560cc evo 8 injectors they are low impendance and It is top feed 11mm and bottom is 10mm. Any benefit from using these instead of 550usdm ones? I'm thinking they might be better because of spray pattern/newer. This will be on a aristo 2jzgte swap
2jzgte is a side feed rail, and the jdm does not come stock with a resistor pack (jdm gte injectors are high impedance).
so you are looking at a top rail conversion and installing the resistor pack.
so basically unless you were looking to go top feed, you have the wrong injectors.
97-SC300
Performance & Maintenance
24
11-04-15 08:50 AM
hcharlesc3
08-20-14 10:25 AM
SimplyZBes
SC400 / 300 Classifieds
05-27-10 07:52 AM
