sc400 info
sc400 info
i found this, i think its the 97+ sc400 but someone on the forum may want to know this info
Engine Displacement: 3969 cc.
Engine Location: FRONT
Engine Type: NORMAL
Engine Max Horsepower: 290 bhp
@: 6000 rpm
Engine Torque: 300 lb-ft
@: 4000 rpm
Compression Ratio: 10.0 :1
Maximum engine speed: 6500 rpm
Transmission Type: AUTOMATIC
Number of Gears: 5
Gear Ratio 1st: 3.36 :1
Gear Ratio 2nd: 2.18 :1
Gear Ratio 3rd: 1.42 :1
Gear Ratio 4th: 1.00 :1
Gear Ratio 5th: 0.75 :1
Final drive ratio: 3.27 :1
Driving wheels: REAR
Car test weight: 3780 lb.
% weight on front wheels: 54 %
Wheelbase: 105.9 in.
Tire section width: 225 mm.
Wheel diameter: 16 in.
Tire profile: 55 %
Coefficient of drag: 0.31
Frontal area: n/a
Overall height: 53.2 in.
Overall width: 70.9 in.
Ground clearance: 5.5 in.
Engine Type: NORMAL
@: 6000 rpm
@: 4000 rpm
Number of Gears: 5
Tire profile: 55 %
Frontal area: n/a
1stsc400
Performance & Maintenance
23
10-14-09 10:20 PM
