97 sc300 iacv wire colors
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
okay long story short'
the idle air control valve connector broke
after tune up'
i tryed to put them back as good as i can remember'
now my car in park idle or "N" idle revs up and down from 1500 to 2k
i bought the new connector and wires from toyota'
but the wires are black and my wires on the car are colored...
now what i need is someone to please tell me or post a pic up of what color goes way'
a pic start off your motor of both sides of the connector or a detailed color placement'
please help'
after tune up'
please help'
after tune up'
please help'
after tune up'
please help'
in the future buy a cheap pack of multi colored zip ties at the dollar store and mark ea wire before ya cut em.....do this on the new connector with all black wires as well
where and what connector did you buy.....i need one
reset your ecu by removing battery terminals 20 mins
i need to know what colors go where' like the blk/red with the brown tip goes and the pink wire and so on'
please help' n i disconnected my battery terminals over night n nathing =/
same problem
ill try to post pics of what i need' i put zip ties on them thinking i got the order right and fail =/
i dont know how to follow that pic you gave me'
See page 3 in the PDF
+12V to terminal B1 (Pin 5) and B2 (Pin 2). Both are in the middle
All S Pins are grounded in a sequence when activated
Pin 1= S2 Light green/Black
Pin 2= B2 Black/Red (does not matter which Black/Red)
Pin 3= S4 Blue/White
Pin 4= S1 Violet/Red
Pin 5= B1 Black/Red (does not matter which Black/Red)
Pin 6= S3 Green Yellow
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
i looked at two different sc300 here in town one 94 and another 96 but the colors where different from mine'
i got lucky and found a connector online that had the colors and i just pug and played it till the idle was back to where it was' so problem fixxed =)
thanks for all the help this wedsite is the best =)
thanks you soooo much guys'
