Ge iacv
no it will not bolt up to the gte intake, you will need a GTE IACV.
on the ge the passages are in the throttle body, on the gte one the passages are built into the plate that the iacv is screwed onto, so you need that middle part which only comes on the gte one.
you may be able to get a 7mgte one to work not sure if the flange is the same size, but the 7mgte one has the same connector, I am using one on my aftermarket FFIM on my ge.
TLDriver
Performance & Maintenance
06-28-09 08:32 PM
