Please help!!!! Car starts backfires when starting to boost.
Old 10-27-12, 07:56 PM
RLJ
RLJ's Avatar
Question Please help!!!! Car starts backfires when starting to boost.
Just finishing my 2jz-gte TT Auto swap on my 93 sc300 and the won't boost, it starts fine but when it reaches 3000 rpm it stars backfiring and won't boost.
Old 10-27-12, 08:46 PM
sj408
sj408's Avatar
Almost like it hits a wall?? maybe check your map out. Im not too seasoned on the turbo setups but ive seen it from a bad map
Old 10-28-12, 09:11 AM
soarer13oy
soarer13oy's Avatar
see if you can pull any codes. I had a similar issue when my timing was a tooth off.
Old 10-28-12, 05:52 PM
RLJ
RLJ's Avatar
I'll check that first thing tommorow really want to get this out
Old 10-28-12, 05:54 PM
RLJ
RLJ's Avatar
Is like so close and so far at the same time.
Old 10-28-12, 07:52 PM
RLJ
RLJ's Avatar
I already rewired the map sensor thinking that maybe it was wired wrong but the same problem.
Maybe will try a new map sensor.
Thanks for your help.
Old 10-28-12, 10:12 PM
soarer13oy
soarer13oy's Avatar
Have you checked your vacuum lines? Youre in Florida so im sure there are members here who can let you test out a map sensor.
Old 10-28-12, 11:57 PM
RLJ
RLJ's Avatar
I'll check vacuum lines and timing next.
Old 10-29-12, 12:23 AM
soarer13oy
soarer13oy's Avatar
No problem! Hope you figure it out soon.
MitYsLiM
04-30-13 04:42 PM
kinch09
SC- 1st Gen (1992-2000)
05-19-11 06:42 AM
1jzlover
GS - 1st Gen (1993-1997)
02-19-11 10:49 AM
nismo2trd
07-31-08 07:59 PM
Quick Reply: Please help!!!! Car starts backfires when starting to boost.
