HELP with blower motor
Sup fellaz,
I've searched but cant find a definite answer...
My blower motor was bad, was making that loud (whirling noise like an animal was screaming) when I turn it on, bearings were bad...
so I replaced it, plug everything back and turn it on for a minute and it works, I turn it off and turn it back on and it doesn't blow any air...no air thru the vents or nothing...
I cant figure out why it stopped working all of a sudden...also the climate control unit is good.
Any input appreciated, thanks.
If you have a multi-meter(or can find one), back probe the connections at the blower motor with it on high, hi-medium-medium-etc... and see if the voltage going to the fan is available, if it is then make sure the connections are good and if so the fan you bought is shot. If no voltage is available check wiring and fuses to the blower motor.
I read somewhere but not sure, transistor or resistor could go bad? but doesnt make sense why all of a sudden...
Fixedd....the fan motor I got from rockauto was shot. I gave it direct power and it didn't spin, so I picked up another one from a local autoparts store and works perfectly.
Geoff240ti
SC- 1st Gen (1992-2000)
07-06-07 01:55 PM
