Recently finished W58 + 1JZ swap into SC. Shifting/tranny issues.
#47
Well, what wouldn't be for a w58? I ordered the SPEC clutch kit from MVP Motorsports under the 5speed SC300/GS300 section, so obviously those are w58 parts. And they perfectly fit my flywheel which also bolted onto the engine with no problem. I was actually gonna call MVP tomorrow to ask them if I should of ordered for the MK4 supra instead of a sc300/gs300 kit, but I don't think that's an issue.
Could anyone else confirm with me if my flywheel is toasted, or is it fine with the amount of face it's got left?
#48
Attached are pics of how the clutch sits on the pressure plate, then how it sits on the flywheel. I just finished picking up my tranny + clutch setup from a shop to look it over and they say the clutch is defective and should sit flat/flush against the contact surface of both. Have we finally found the culprate here guys?
#50
I made a few calls, and definitely this is a clutch defect. Thanks for all your close support CL members. I'll keep you updated on the final status of this issue. I'll be ordering a Exedy clutch next.
