Chaser? 1j in sc
Old 11-16-12, 07:21 PM
scbmxr
scbmxr's Avatar
Default Chaser? 1j in sc
Soo, I got a good deal on a front sump 1j for my 96 sc300.
I'm wanting to keep the auto tranny, pretty much just a stock swap for now.
Still not 100% sure what the engine came out of exactly, it was listed as soarer/aristo/chaser.
But I know it's not a soarer engine because of the rear sump, and the wiring harness was cut at the bulk where it came through the firewall, so I couldn't know the amount of pin rows for the ecu plugs. I could use some help identifying what exactly it came out of...
Anyways, I've heard wiring can be a rat bastard on the chaser swaps, someone correct me if I'm wrong, but if I have the sc wiring harness and soarer ecu, most of the sensors should be in the same place I would think?
Thanks
Old 11-16-12, 09:39 PM
nuturf87
nuturf87's Avatar
whats up dude...... congrats on the 1j...lol. i believe if im not mistaken the soarer ecu should have 4 slots going across, if its a soarer harness it should have an ik1 orange plug, but in this case you said its chopped off at the plugs. do you have the ecu? There is a thread on here that gives the info you are requesting... its not that hard of a swap. GL!!!
Old 11-17-12, 05:45 AM
spoolxexo
spoolxexo's Avatar
And
Open up the full links in Youtube, I explain everything under the description!
Old 11-17-12, 07:03 AM
kez
kez's Avatar
I'm throwing chaser 1jz in my sc at the moment. I got lucky and found a Soarer harness if you search around you'll prob find one for cheap.
GOODLUCK with swap
Old 11-17-12, 08:07 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
This thread is useless without pictures!!!
Old 11-17-12, 11:26 AM
nuturf87
nuturf87's Avatar
you got a point.... with no pics its just gonna be tougher to explain...... POST PICS!!!!
Old 11-17-12, 05:24 PM
robtackett
robtackett's Avatar
goog luck with the swap no matter which engine it is. I think the one I put in my 93 sc was out of a chaser. Its the newer one though with vvti and single turbo. I used the stock ecu trans and wiring harness from the swap. The wiring was kinda a nightmare. lol
Old 11-17-12, 07:36 PM
scbmxr
scbmxr's Avatar
Thanks for the info,
haha sorry guys, ill post up pics tomorrow
Old 11-18-12, 06:14 PM
scbmxr
scbmxr's Avatar
Heres pics of everything...
Old 11-20-12, 09:23 PM
scbmxr
scbmxr's Avatar
Okay, so i believe the engine is from a chaser. but thats aside the point because i dont have a functional chaser harness or a chaser ecu... Could i run the soarer ecu with my sc harness?
If so... ill need to extend the harness, and what other wiring would be involved?
Im not sure why the chaser 1j is being made out to be a wiring nightmare to some people, maybe im overlooking a few main points.
Im sure its all on the web somewhere, but im having trouble finding the info here that i need.
any help?
Old 11-21-12, 08:03 AM
TweakTech
TweakTech's Avatar
The chaser harness isn't any harder to do than a soarer, people are just lazy.....
either way, as for the harness you have, just about every identifying portion of the harness has been cut off. Any 1JZ harness will work on that engine, but will need modification to work in your SC chassis.
Old 11-26-12, 06:50 PM
scbmxr
scbmxr's Avatar
Is there any write-ups on any of the harness conversions?
Old 11-26-12, 07:17 PM
scbmxr
scbmxr's Avatar
...also from what i read the chaser and soarer ecu's are the same, just a difference in auto and manual ecu's.
so would it matter which engine harness i bought, just as long as i get an auto ecu?
Kind of repeating what you just told me, tweak, but just trying to understand a little better lol
Old 11-27-12, 07:57 AM
TweakTech
TweakTech's Avatar
Nope, you're correct. Any 4 row auto ECU will work for your setup. You can even keep that ECU if you ever decide to go manual down the road.
The Chaser harnesses will have 2 of the ECU plugs missing, and they will need wired in, and also the body plugs changed. The Soarer harnesses have all 4 of the ECU plugs, but will need altered to work in a USDM chassis. There ARE write ups on the forums...but I've looked through about half of them, and had to turn away because of all the false information.
Old 11-27-12, 06:26 PM
scott101
scott101's Avatar
what car is this from? is its from an earlier chaser like a jzx90? cause I think all the newer chaser motors I see look different
please excuse my stupidity, and good luck with the swap, I would love to have a 1j
-scott
IneednSC
10-04-14 03:06 PM
soarer479
05-06-13 02:59 PM
BrownGuy
Florida Lexus Club
02-19-11 08:43 AM
lakiulo
SC400 / 300 Classifieds
08-16-07 01:01 AM
Quick Reply: Chaser? 1j in sc
