98 Sc400 shakes and trac light flashes and check engine light is on now
Whats going on sc owners, i am having trouble with my 98 sc400. when at a stop with my foot on the brake the car will start to shake and the trac light will flash and now my check engine light is on. The only thing I had done recently was a new alternator, any ideas?
Thanks...
Thanks...
Throwing cel code p0301 - A P0301 code means that the the car's computer has detected that one of the engine's cylinders is not firing properly. In this case it's cylinder #1. So now that I hope i got the issue isolated can anyone recommend good spark plugs, I heard ngk's are good, any other suggestions?
I check the spark plugs with a friend and the look good, and they were ngk so we swith the spark plug wires on the two front and I replace the one spark plug in bunk 1. See what happens
Brownd3max
04-28-18 04:37 PM
aznsupra
Performance & Maintenance
01-22-16 07:24 AM
21colvera
07-18-09 12:14 PM
