Questions about 1JZ Hose Routing
Old 11-27-12, 03:41 PM
Toyboxx
Toyboxx's Avatar
Default Questions about 1JZ Hose Routing
Hey guys so I'm confused about a couple hoses.
Just can't figure out where they connect.
Below I have included a picture of what hose I'm referring to.
Any clarification would be greatly appreciated. Pictures would be even better, as I understand it better if there are picture rather then reading. But any help is welcomed.
Old 11-27-12, 03:48 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
The larger hose goes to the heater contol valve on the passenger side. My thread has this info covered for you. LMK if you need more help...
Old 11-27-12, 04:08 PM
Toyboxx
Toyboxx's Avatar
I've been watching your thread like a hawk. Pretty sure I understand where the larger hose (#2) connects. However hose #1 has me scratching my head. Where you think that one goes?
Old 11-27-12, 04:20 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Post a better picture of it. Hard to tell from this angle.
Old 11-27-12, 06:54 PM
blk&blu*j
blk&blu*j's Avatar
Hose 1 goes to the IACV on the intake manifold.
Old 11-27-12, 07:09 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
^^That sounds about right, around the IACV area if not the IACV itself.
Old 11-27-12, 09:49 PM
vangb2
vangb2's Avatar
To me, it looks like the 2 hose goes to IACV unless if it's the hose in the front which goes to the heater control valve. I can't tell which hose you are trying to circle.
Old 11-28-12, 07:06 AM
93MSB
93MSB's Avatar
#1 looks like fuel return line, I need a better pic though.
#2 is definitely the coolant hose for the heater core
Old 11-28-12, 07:43 AM
Toyboxx
Toyboxx's Avatar
That's what I'm thinking I won't be able to get better pics till later, since it's at my buddies house.
I agree. Although I put a filter on it and then plugged the line by the turbo piping, but I'll check.
It's deff not the fuel return line as the hose I'm referring to is connected to the hard water pipe that runs in the back of the block.
#2 I guess connects to the heater control valve.
Anyone know the hose routing way? Also the two inlets on the firewall. I believe one is a return & one is a feed to the actual heater core, any pics on how those are routed?
Old 11-28-12, 07:51 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
It almost looks like the thermostat hose. ???
Old 11-28-12, 08:40 AM
Toyboxx
Toyboxx's Avatar
Here is the picture now that the motor is installed.
That is the farthest it will go. I cannot pull it out anymore, and it won't reach to the IM where I have that white cap.
Old 11-28-12, 02:18 PM
93MSB
93MSB's Avatar
ok if its a small coolant hose its more than likely for the IACV. The iacv has two coolant ports to help with cold starts.
here are some pics of iacv coolant lines
Old 11-28-12, 04:23 PM
Toyboxx
Toyboxx's Avatar
Thanks so much for being detailed with it. Now the question comes up, can I bypass this? I have caps on those ports on the IACV. If I cap where that hose comes from on the hard water pipe, is that going to affect drive ability or start up?
Old 11-28-12, 04:57 PM
93MSB
93MSB's Avatar
yes you can, your afr may be a little rich at cold starts until the engine warms up after a few min but that's it. it does not affect drivability
Old 11-28-12, 05:15 PM
Toyboxx
Toyboxx's Avatar
Cool thanks so much for the info! You've cleared it all up for me! I will be capping that off, since I have already capped off the IACV ports.
One more question to you all, so I don't start another thread on it.
Doing a 5 speed swap, I've installed the clutch pedal, and the pedal sticks to the floor. Take into consideration, I have not put any tranny or clutch fluid in. So I'm thinking that's typical, but would like some clarification.
Quick Reply: Questions about 1JZ Hose Routing
