1jzgte Exhaust manifold gasket/ Turbo oil outlet
Old 11-27-12, 05:29 PM
jasonxle
jasonxle's Avatar
Default 1jzgte Exhaust manifold gasket/ Turbo oil outlet
So I bought a 1jzgte and I need a new Exhaust manifold gasket and turbo oil outlet gasket. I've tried searching up part #'s and I went to the dealership and tried 17173-88400, and 15472-88400, and nothing came up. Any ideas or place to buy these things? I only need these gaskets, as I've replaced most other things already, Head gasket, intake manifold, front main seal, rear main seal, etc...
Old 11-27-12, 06:19 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Buy the complete kit from DM (Driftmotion)... Use what you need out of it, then sell the rest on here after a 100 posts.
Old 11-27-12, 08:15 PM
scmaluco
scmaluco's Avatar
I believe those are the thick paper ones or whatever that material is.. kragen/O'Reilly have a roll. $5"max. Buy a roll and cut the shape you want. Its easy. And iam pretty sure its the same material. Thats what I did for my single turbo oil drain flange..
And for your exhaust just reuse the ones you got unless they are broken or in pieces..
Oh and may I interest you in a pair of stock manifolds ported out . Better response for the twins..
$50 im in cali also pm me if you are interested..
Thanks
Old 11-27-12, 08:18 PM
frankdms
frankdms's Avatar
Have you tried to contact the Club Lexus Vendors?
Old 11-28-12, 12:34 PM
xspsi6
xspsi6's Avatar
Just spray copper coat on them and re use.
Old 11-28-12, 12:37 PM
xspsi6
xspsi6's Avatar
I have a set of new ones un used for 25 shipped if you need?
Old 11-28-12, 03:02 PM
speed6
speed6's Avatar
driftmotion will sell you anything you need. call aaron
Old 11-28-12, 05:35 PM
jasonxle
jasonxle's Avatar
Thank you guys for the info, @xspsi6 I'll pm you.
suprakidxx
30
06-20-13 12:37 AM
1JZPWRD
38
06-10-13 07:15 PM
redSOARER
SC- 1st Gen (1992-2000)
02-04-11 03:49 AM
100mgbluep
12-27-07 09:41 AM
T0ked
09-06-05 01:37 PM
Quick Reply: 1jzgte Exhaust manifold gasket/ Turbo oil outlet
