Timing Belt Lasted 200,000 Miles Tensioner Fell Off
I bought my 94 SC400 back in 2004 and since then I put 200,000 miles on it and never changed the timing belt. Just thought I would share this info. Unfortunately, I do not know who manufactured the timing belt. And the timing belt probably would have lasted longer if the t-belt tensioner didn't fall off the car while on the highway.
Now I have to figure out how to re-attach the tensioner now that the threads in the block are stripped. In the process of removing everything to replace the t-belt, water pump, oil seals, and anything else I find faulty.
Is it pretty easy/straight forward to replace the crankshaft and camshaft oil seals?
Wow! That's a lot of miles on a timing belt. Like Ali SC3 mentioned, you can drill and tap for a larger diameter bolt or drill and tap and install a heli coil and use the original bolt size for the tensioner.
sayow
12
05-01-14 11:45 AM
