My Headache for the last 2 weeks!
Hey guys
I've been having some problems w/my SC (92 Sc300) it will constantely shake/almost die when i'm at a stop/idle. I was on the way to school this morning and it died on me check engine light came on oil light and batttery light came on as well. I started it back up and it was a little hesitinate to start but eventually did, then it died 3 more times. I pulled over and let it sit for a min and it started up and I got to school. I'm noticing it a lot more after i've been driving for a while and the car's been warmed up or during traffic. I did do a code check and the check engine light blinked constantley w/no pauses and the overdrive light was blinking as well.
What I think it could be:
1. Fuel Pump
2. Fuel Pump ECU
3. ECU
4.MAF
5. Idle air control moduele
This has been going on for two weeks now and i've had the car in at a shop and of course it runs fine when they look at it.
Any ideas/comements would be greatly appreciated
Thanks
-Nick
1. Fuel Pump
2. Fuel Pump ECU
3. ECU
4.MAF
Thanks
-Nick
In Recovery Mode
What did the codes say? It could be any of the things you mentioned as well as the ECU, vacuum leak, and maybe even TPS. I would also dump a container of injector cleaner into the tank, never know..BTW, almost any car anybody get's will be a headache. whether it's a tempo or veryon...
sounds like it could be the main ecu.
fuel pump and fuel pump ecu would be more of a constant problem not very intermittent, at least not for long.
IACV would be a constant problem.
It could be the maf, but I would expect it to run rough all the time then and probably throw a code usually if not the maf code a lean or rich code or o2 code.
sure way to check the ecu is to swap with a known good one, or pop it open and have a look around inside.
thanks for the input guys, helped me narrow it down a little more. Also does anyone think it could be the cap and rotor along w/an ignition coil? My dad and I are going to put a new cap and rotor on tonight will see what happens
miraluna
Performance & Maintenance
14
10-28-10 09:18 PM
