Which a/c lines need changed when gte in a sc400?
Old 12-04-12, 02:22 PM
xspsi6
xspsi6's Avatar
Default Which a/c lines need changed when gte in a sc400?
I have all of the lines from an sc300 however I can't find any info on just which exact ones need changed.
I thought all of them needed changed however my friend thinks it's just a few so I am at a loss.
Old 12-04-12, 03:01 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
All the lines from the firewall to the compressor needs to be changed. This includes the high pressure hoses for the high and low side on the compressor. This is noted in my thread in my signature with pictures. GL.. Let us know if you need more help.
Old 12-04-12, 03:03 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I would also replace all the orings with new ones from the local parts store. Mine had zero leaks and has worked like a champ ever since the AC charge. Are you using piggyback or AEM or Protech or Haltech?
Old 12-04-12, 03:53 PM
xspsi6
xspsi6's Avatar
Ok thanks! I will be using pro efi and yea the o rings will be replaced as well as the reciver drier also I am good to use the sc400 condenser?
Old 12-04-12, 04:21 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
That is what I am using. Works great!!!
Old 12-04-12, 04:46 PM
xspsi6
xspsi6's Avatar
Good deal, Thanks for clearing up the confusion!
Old 12-04-12, 04:49 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
No problem. Thats what the forums are for... lol.. glad I could help out.
Old 12-04-12, 09:59 PM
rcchris7
rcchris7's Avatar
Dang. I thought I'd get away with the ac lines since compressor is in the same location. What are you guys using for power steering lines? I'm guessing sc300 as well? Wish we had sc300 here in Canada would have made things a lot easier
Old 12-04-12, 11:04 PM
xspsi6
xspsi6's Avatar
I am using custom -6an fittings and hose for mine with a soarer ps tank in the stock location.
Old 12-05-12, 12:05 AM
rcchris7
rcchris7's Avatar
Already got the soarer ps tank. Just gotta get lines sorted out while the bay is empty.. Guess I'll be grabbing the lines when I grab a/c compressor and oil pan. Thanks guys
Old 12-05-12, 12:37 AM
rcchris7
rcchris7's Avatar
Finally got to page 21 on 1JZPWRD build thread... Thanks pal you're really making this easy for me!
Old 12-05-12, 05:01 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Your welcome man. Anytime. The whole reason for my thread!!!
Old 12-05-12, 09:30 AM
LexusFTW
LexusFTW's Avatar
Only the flex lines at the compressor need to be changed. All of the 1997 SC400 AC hardlines can remain in the car.
Old 12-05-12, 04:57 PM
xspsi6
xspsi6's Avatar
Ths is what m friend told me as well.Hmm now I a confused
Old 12-05-12, 05:03 PM
rcchris7
rcchris7's Avatar
I'll be a test pilot if need be... I;m going to the junkyard tomorrow to grab compressor from 2jzge I will grab the flex lines and maybe oil pan in case I get a front sump.. I'll see if it looks like it'll all bolt up
Quick Reply: Which a/c lines need changed when gte in a sc400?
