90mm throttle body Godspeed?
Old 12-06-12, 05:57 AM
jwin
jwin's Avatar
Default 90mm throttle body Godspeed?
Has anyone use this throttle body? I know its ebay cheap stuff, but if it works then I could spend that 200 that I save on something else.
Old 12-06-12, 06:05 AM
jwin
jwin's Avatar
Nevermind. After some more research the throttle body has a tendancy to leak. Figures why it cost 200 bucks less.
Old 12-06-12, 08:35 AM
99SC42
99SC42's Avatar
Q45 tb works great !
Old 12-06-12, 08:52 AM
hmhatch
hmhatch's Avatar
You get what you pay for. Godspeed among other ebay companies have a lot to be desired in the quality department.
Old 12-06-12, 11:05 AM
Ali SC3
Ali SC3's Avatar
I came to the same conclusion that they all leak except the very expensive ones, I went with the q45 TB it works great.
Old 12-06-12, 04:04 PM
lexforlife
lexforlife's Avatar
qb for sure .. however bare in mind the rubber seals at either end will and do leak but there is a easy fix for it on supraforums
sagarx
12-03-20 03:50 PM
Dukenukemx
RX - 1st Gen (1999-2003)
09-25-19 04:51 PM
daileycon
Performance
02-23-14 11:32 AM
NEbiker10
03-22-11 09:54 PM
Quick Reply: 90mm throttle body Godspeed?
