lots of blow by
Old 12-13-12, 09:04 AM
Ali SC3
Ali SC3's Avatar
HG is a possibility because you have 2 cylinders low right next to each other, especially if you find the 'ol milkshake in there. I would probably pull the head and take a look, see if those cylinders have any scarring also from bad rings.
Old 12-13-12, 04:25 PM
duhafnusa4
duhafnusa4's Avatar
stock na.
sounds good, ill have the head off tomorrow
Old 12-14-12, 07:03 AM
MDSC
MDSC's Avatar
Originally Posted by Tabaka
GE or GTE?
If GE, unbolt motor mounts, throw engine in garbage
find $1000 1J or $1500 2J at engine importers
reverse uninstall method
smile again
LOL this is a bad advise for anyone that might take this seriously. Multiply that times 5 maybe more then you got a swap.
Old 12-14-12, 07:07 AM
MDSC
MDSC's Avatar
Its hard to say i would def do a leakdown before anything. It could be combination of h/g and valve seals. Are you loosing any coolant from the reservour at all? Mine when it blew never overheated for over a year i was adding coolant into overflow but it wasnt leaking. I would also check the block very cerfully if you remove the head for pitting around the coolant ports on the block. It is a very commen problem with most toyotas.
Old 12-14-12, 10:46 AM
duhafnusa4
duhafnusa4's Avatar
sadly I dont have access to a leak down tester :/
Spadednick
06-18-17 05:18 AM
lemmiewink
01-08-11 07:45 PM
SC300_704
02-22-10 01:35 PM
MJB_LEX
08-02-07 01:28 PM
Quick Reply: lots of blow by
