Ive got some stock pistons from a 92. But you may just need a ring set, not entire pistons. Put some oil in the cylinders and retry the compression test.
If GE, unbolt motor mounts, throw engine in garbage
find $1000 1J or $1500 2J at engine importers
reverse uninstall method
smile again
lol, turning to the darkside. I would just add oil and turn up the boost before doing that (kidding)
you could just go with a good GE longblock. maybe just buy a whole sc300 that needs some body work.
thanks for the input. fyi i got it up to temp and drove it around, when i was done, I found coolant in my oil, an vise versa, any chance this could be a bad HG?
