NA-T Cam Opinions
#46
Yes they are regrinds, thus they have to remove material from the base circle, which results in needing lash pads to account for that.
As for install, I had a shop install them. Performance, I haven't gotten power pulls done yet with the new setup so all I can comment on would be partial throttle and idle. Idle has a very slight lope now but not bad. Throttle response still seems decent. So far I'm happy with them.
#47
#48
Here are the measurements Schneider said my stock cams came in at.
Part Number: stock
Grind Number: 2JZ-GE
Intake Duration (gross): 240
Exhaust Duration (gross): 248
Intake Duration (.050?): 197
Exhaust Duration (.050?): 203
Intake Valve Lift*: 8.5mm
Exhaust Valve Lift*: 8.7mm
Lobe Separation: 112
Intake Valve Lash: .012"
Exhaust Valve Lash: .014"
RPM Range:
1000-5000
I then had them do his standard 268 regrind on them with the following spec.
Part Number: custom
Grind Number: 268F
Intake Duration (gross): 268
Exhaust Duration (gross): 268
Intake Duration (.050?): 226
Exhaust Duration (.050?): 226
Intake Valve Lift*: 9mm
Exhaust Valve Lift*: 9mm
Lobe Separation: 114
Part Number: stock
RPM Range:
1000-5000
Part Number: custom
Grind Number: 268F
#49
Sorry to bump this oldish thread..but how are these working out for you?
Also, what head gasket/head/bottom end setup are you using? I am curious because I will end up ~ 9.8ish:1 compression and am wondering what sort of lift I am safe in using..I think the 9mm lift like you have would be fine, but I am curious what your setup is for comparison..
