1997 SC400 2 Alternator burned
Old 12-16-12, 09:17 AM
stratman3
stratman3's Avatar
Default 1997 SC400 2 Alternator burned
They have burned do to oil leaking into it. Now this is what I've done so far, replaced valve cover gaskes, replaced power steering pump. It looks like motor oil to me but it's definitely not from the valve cover, it's pretty dry around there. When I reach down under the alternator with my palm facing up and grab the alternator, my hand always comes out with oil. Any Ideas anyone? Thanks
Old 12-16-12, 10:34 AM
OG Dada
OG Dada's Avatar
I went through this, lol. Mine turned out to be cam oil seal and bad oil pressure switch. Burned 2 alternators in 1 year cause of this, until the leak became worse.
Old 12-16-12, 12:56 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Either power steering fluid or what KingPhilip said.
Old 12-18-12, 05:42 PM
stratman3
stratman3's Avatar
It definitely looks like it's engine oil. When I replaced the power steering pump, I don't recall seeing an oil pressure switch. Where is it located? Also, I'm thinking it's the cam seal because of the way it drips down to the alternator. Is there a diy on the cam seal replacement?
Volunthai
12-30-16 08:45 PM
covert
06-12-15 08:37 AM
eknine9
11-21-13 06:02 AM
AoiHeiwa
01-24-11 07:42 AM
dl11
09-28-10 04:14 PM
Quick Reply: 1997 SC400 2 Alternator burned
