Can any one help me identify if this harness is from a 1jz soarer or a supra
Hi!
Im looking forward to do a 1JZ SWAP in my car 93 SC300 5 Speed, but i am having a hard time identifying the harness, because i want to extend the harness and pnp into my sc300 and save money from Dr. Tweak. However, i will go that route later when the money comes in, but for now i want to try and use the harness that comes with the engine.
The importer has sent me a video of the harness, i will have better pictures and videos tomorrow of the harness.
Can anyone tell me if this harness is from a soarer or a supra?
Here is the link
Thanks,
Lokesh
Here is the link
Thanks,
Lokesh
ECU has 2 rows of pins, plus that extra plug off the ECU and some plugs i don't recall seeing on my harness before, so that's definitely a MKIII unit. As far as a Soarer harness being plug and play on a Supra motor im not 100% sure it is or not. Plus kinda hard to find a Soarer harness without getting an engine to go with it. I say pass on this engine and wait for a Soarer.
Definitely mk3 supra. Not a big deal. If you still have the stock sc harness, it's not difficult to make thios work in your car. Lots of people will say don't do it because the ecu is known to blow caps. Well guess what? So do jzx90, jzz30, aristo, even stock sc300/400 ecu's. One of the things I like to tell people that want to do a swap is to make sure you have a spare ecu and a spare map sensor, just in case. It's also not difficult to rewire to a later model or aristo ecu. You can get the plugs for the different ecu out of pretty much any junkyard. As far as soarer harness going on mk3, it would work like 99% IAT plug is usually different, possibly the 2 wire coolant temp sensor too, no big deal.
If you take your time, you can do the wiring no problem. Anybody can, and you'll have a better working knowledge of your vehicle in case anything comes up later problem-wise. A factory wiring manual for the SC will make it cake. Read the section in the beginning of the book called "how to use this manual" ( i think that's what it's called). Get a multimeter (harbor freight has one that will do just fine for like seven bucks), and be thorough. If you have a frye's electronics around, they have great heat shrink. Any electrical shop and possibly hobby shop should have something decent though.
Also, I wouldn't worry about what water pump comes on it as you should replace it with a new one anyway before you put the engine in. A mk4 turbo pump and pulley will be needed, what ever you do, don't cheap out and neglect seals and waterpump.
i suck at wiring. and i would never attempt it(cause well i suck at it). if your 2nd guessing yourself. contact account 2x on here. he did my harness and it's perfect(my temp gauge even works).
if hes not busy with school his turn around time is quick and his prices can't be beat!!
BigWaveSC
SC400 / 300 Classifieds
11-25-11 01:15 AM
