Torque specs for 2jzge with arp studs
I have a 2jzge with jza80 arp studs, i'm getting ready to torque the head down...(again) but this time I have an oem 2jzgte head gasket to go with it, do you guys know if the torque specs are different depending on the head gasket? Because last time I put it all together with the ge head gasket I hand tightened the studs on the block and tightened the nuts to 80 ft-lb doing increments of 25lbs. Is it the same with the gte head gasket? Thanks in advance
I personally have never retorqued H Studs in 15 yrs and making through 900 hp but I don't think its a bad idea however I also have my block O ringed mention that on SF and you will start a barrage of ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
and ![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
To each his own and it has served me well!!!!!!!!!!!!!
no retorque on a jz motor .. use moly lube correctly .. do not use a typical cheap click type trq wrench either . they are never calibrated correctly and will give false readings.. i use the snap on digital self calibrating type that beeps when trq is reached .. make sure on final trq , you hold pressure on the fnl sweep just to make sure its holding trq and not slipping on the nut or worse , galling into the head ..
