Where is this oil leaking from?
Old 12-21-12, 10:21 AM
BradHoff
BradHoff's Avatar
Default Where is this oil leaking from?
Looks like its dripping down the brown cylinder, between the alternator and crank. The leak is pretty slow although sometimes it seems like its on and off.
87k mile 95 SC400 and i noticed the leak after i was lowered scrapping around in Tallahassee.
Attached Thumbnails Where is this oil leaking from?-img_1289-1-.jpg   Where is this oil leaking from?-img_1288-1-.jpg
Old 12-21-12, 10:54 AM
OG Dada
OG Dada's Avatar
I had the same leak. It might be coming from the cam seals or valve cover gasket.
Old 12-21-12, 11:12 AM
BradHoff
BradHoff's Avatar
Did one of those fix your leak?
Old 12-21-12, 01:06 PM
LEXXIUM
LEXXIUM's Avatar
I hope it's not your front main seal , it could also be your oil pan gasket.
Take a closer look with a hid flashlight and try trace the oil leak source.
Looks like your belt tentioner is wet
Old 12-21-12, 04:40 PM
OG Dada
OG Dada's Avatar
Yes. That's why I said "I had". Lol
Ishinc
02-11-19 01:29 PM
durtysc300
04-27-10 04:38 PM
GS300 I6
GS - 1st Gen (1993-1997)
03-07-10 11:40 PM
handzilla
12-04-07 10:28 AM
jgrill5
01-04-06 11:10 AM
Quick Reply: Where is this oil leaking from?
