1Uz Flywheel choice
Hello!
i will next year my SC400 swap to manual with a W58 tranny.
i look longer time in the www for a flywheel, and i found sveral flywheels.
Ok..the modified 3VZ Flywheel is no option for me.. too much risk to break and more.
I found the Fidanza flywheel for the 1UZ Landcruiser, but which clutch will fit? no more informations to found. Have somewhere installed this?
from 1uzfeswapkits gives the modified 3VZ FW or i think the fidanza or fidanza style with the friction disc.
![](http://www.1uzfeswapkit.com/images/13108549105631136419779.jpeg)
![](http://www.1uzfeswapkit.com/images/430215_361214223896768_100000245791529_1416362_769755723_n.jpg)
from dellowconversion gives a flywheel, 10kg, new part and a standard W58 clutch fit.
![](https://lh6.googleusercontent.com/-rjtEwaV_02g/UNyUVsEnD8I/AAAAAAAAHRY/XpnDdtSB-9o/s482/flywheel%2520dellowconversion%252010kg.JPG)
i found from xatracing a 11lbs(!) flywheel! wow.... but is this strong enough for a daily and little bit fun?
![](http://ep.yimg.com/ca/I/yhst-75936728794975_2208_8355683)
which flywheels used her? is alloy or steel better? i will only a NA 1UZ with some mods and in the future a stand alone![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
greets
Tom
greets
Tom
I wasn't even aware that Fidanza made a flywheel.
I used a flywheel that was made by SuperRunner. I purchased it second hand from someone else and have had no problems with it.
The biggest problem I see with an 11 pound flywheel is that the RPM's would drop too fast for it to be a good daily flywheel.
hy ihiryu!
Fidanza have the flywheel in his part list for the Land Cruiser.
yes, 11 pounds can give a problem for a daily, you´re right. A friend of me have in his IS300 GE-T a very light fw, is only good for drift and race,but on the street is it horrible
thanks for this hint.
hey man ive got a Quantum auto flywheel for my SC4. you can check out there site they offer different ones. http://www.quantum-auto.com/products.html
hey heres the link for the steel one:
http://stores.boldperformance.com/-s...eel/Detail.bok
And Aluminum
And Aluminum
I have the steel fw from Quantum, great for daily driving. Over 5k miles now on my w58 swap, no issues whatsoever.
I do not know what your plans are with your car but for daily NA, a steel flywheel would be sufficient,
@axmily...i orderd the steel flywheel yesterday
thanks again for the link!
@mr2tosc4... i think the steel is the right choice. i will go the must time on street and sometimes on track for fun. My first idea for 2 years was to install a blower, but in the future i will go NA Tuning with other headers, Stand alone, DIY Inlet manifold and and and
it gives very much ideas and projects of this engine
but first, i install in the spring the LS400 calipers
no, is a new one!
here form the bolt performance site:
This flywheel is a must have to convert your UZ Series engine to a manual transmission. This flywheel is designed specifically to work with a Quantum Auto Clutch Kit or a 86-92 Toyota Supra NON Turbo Clutch equivalent kit. This is a standard steel flywheel modified to work with the 1UZFE engine, using the correct ring gear, thickness, and bolt spacing. This flywheel weighs under 20lbs, which is fairly light for a large steel flywheel. - Includes matched (8) OEM Toyota Flywheel Bolts * Please note, product is made to order, and may encounter a 2-4 week waiting period. Please contact us if you have any questions. ++Please also note, this is NOT a modified 3SGTE flywheel, the teeth of that flywheel are facing the wrong direction for the UZ starter. Don't use the wrong flywheel!
Tom
[QUOTE=SCary400;7684247]I'm assuming the Quantum steel flywheel is the 3vz redrilled wheel, yes?[/QUO
Both the quantum and the 1uzfeswapkit.com flywheels are modified 3vz flywheels.
and, they are not redrilled, but instead endmilled out less than 1/32" of an inch. Not much chance of breakage. and between both companies they have probably sold over 500 flywheels and noone has raised any issues so far.
the xat flywheel is a modified 3sgte flywheel and the holes get milled out almost 1/2". and the ring gear lead is in the wrong direction. Scary ****!
