DIY $30 Adjustable Boost Cut Eliminator
#31
I totally forgot about this, and I still haven't tested it, but I am going to upload the file so others can mess around with it or have it printed. You can use it freely but do not charge others cause its right here for free. I used express PCB which you can download online and then you can tweak it if you want to make changes etc....
Once you download the file, you will have to edit the filename and remove the ".txt" at the end because the forum wont let me upload the pcb file so i had to add ".txt" at the end. once you remove the ".txt" it will open in pcbexpress.
#32
