NA-T Your Thoughts!
adding a tt hg to a ge piston setup gives you around 9:2:1 compression..optimal setup would be using a gte piston and ge hg with the better arp studs which will yield around a 9:6:1 compression so there you are using piston dish to lower compression as opposed to raising deck height
dont quote me on that one but i imagine tt ecu with an safc could pull 450 no problem
edit: just realized ali beat me to it hahah
I imagine you could get 400 or so out of 440s but being at a very high duty % if not max. Why 660s though??? go for a TT ecu with 550cc injectors and adjust fuel with a simple afc.
One thing I noticed about duty cycle, once the TT ecu gets close to full boost it literally just goes to its max safest duty cycle on the injectors, because my gauge goes 10:0 rich at a certain point and doesn't get any leaner even with my boost at 14 psi now. Im sure its not 100 percent duty cycle, its whatever toyota decided was the safest max duty cycle, and this duty pulse does not change when you install larger injectors, only changes when you use a fuel controller to adjust it (which usually people do when the install larger injectors).
Point being, you can turn up the boost on your 440's till you get a safe desireable airfuel ratio at max boost something like mid 11's. This will be "maxing out" on your 440's because past a certain point the ecu injects the same max amount of fuel. this is not dangerous because the stock ecu does not run the injectors at a dangerous duty cycle just cause you turned up the boost. it will always inject the same amount of fuel past like 12 psi of boost.
That being said you can install 550's or 660's and reduce this duty cycle via an safc (remove % all across the map on low), and it will run similarly as it did before, but now you have room to run more boost keeping a safe AFR and a safer duty cycle, as it is unlikely in most cases that the extra fuel you add in with larger injectors will be larger than the original duty cycle. unlikely but not impossible though.
Wow!!! So much awesome information! this is exciting stuff!
Ok. So 550 would be ok. HEHE Save me some money I understand what youre saying by going OVER the amount that I need.
I really want to do the ARP HEADSTUDS and TT GASKET cause I dont want to change the pistons yet.
So right now. Im gonna go read up on the modding a TT into my car. So ill definitely post back here after I learn more about it. Dont wanna yap things I dont truly understand.
Question while im here. I read that the GE intake manifold produces more torque than the GTE intake manifold, however I see people selling the GTE "like" intake manifold for the GE. I guess airflow is easier for the GT intake cause i dont have to wrap and bend the intercooler from the right all the way to the left.
Long story short how much torque is more torque and what about the Throttle body? Would I have to redo the cable?
Cause if the GE and GTE head was simliar than changing the gasket and the pistons would make it 8.5 since the bottom ends are the same. Correct?
And you still havent called me -.-
ge and gte combustion chambers are different . doing the tt hg with ge pistons is fine , i was just illustrating what a optimal setup would be ..actually using gte pistons and hg lowers you beyond 8:5:1 and actually makes setup MORE prone to detonation
the ge intake produces a little more torque and gets you a little more spool when using the GE ecu that controls the intake (not sure if the tt ecu can control the stock intake yet). its not that noticeable though and couldnt be more than 5-10 ft/lbs and thats purely a seat of the pants guess. you will loose that probably with the tt ecu mod but its not that important.
The FFIM for most is an aesthetics upgrade unless you have a turbo with a 3" compressor outlet and 3" intercooler and piping. the stock throttle body is 2.75" roughly, so you can see how a larger throttle body would help in that scenario. most of the entry level kits though have 2.5" compressor outlets and 2.5" piping and if thats the case you wont see much benefit from the FFIM. Only things that will benefit will be intake temps and easier access to injectors and plugs.
Its alot of work to go FFIM, new throttle cable, new throttle cable mount, removing a whole bunch of stock vacuum stuff, relocating the battery, getting the idle valve welded on or adapted, then routing all your new piping and setting up a vac block for your accessories or drilling and tapping the ffim for that. where you are now, the last thing I would worry about is the intake. the stock intake performs very well with a turbo, just make sure you have a good intercooler as the only issue the stock manifold has other than the size thing is the intake air temps will be hotter.
get a turbo blanket and wrap your charge pipe where it sits on top of turbo and you will be fine.
I would definitely say save up and try to catch a deal on an AEM V1. I went from a map ECU to the V1 years ago on an NA-T supra and it definitely was like a night and day difference.
deathsled
Performance & Maintenance
12-30-11 09:42 AM
kmn5
06-21-03 10:58 AM
