1jz wiring help
I have 2 connectors that goto the engine fuse panel which was a 8 pin plug and a 3 pin plug the 1jz has a 8pin plug which plugs up and pins out right but it has a 4 wire plug instead of a three wire plug anybody have any experience with making a jumper harness or where to splice them together
Here:
http://wilbo666.pbworks.com/w/page/4...JZZ30%20Soarer
and go to the bottom of the page, you'll know what each wire do! Those infos are corrects, I can confirm as I own a soarer!
