Instrument Cluster..removal easy...But the wires ????
Old 01-15-13, 08:45 PM
kmoore737
kmoore737's Avatar
Default Instrument Cluster..removal easy...But the wires ????
Speedometer is barely registers, removing the cluster to investigate the speedo motor. Got the cluster out and disconnected the wire bundle on the far left...but the other two wire bundles I cant get to budge. What is the secret to those two???
Old 01-15-13, 08:52 PM
1sWt2GS
1sWt2GS's Avatar
have u tried looking for if they are clipped on?
Old 01-15-13, 09:01 PM
kmoore737
kmoore737's Avatar
Yep, the one on the far left did have a tab that I pressed to get it to release. The others dont seem to have any visible means of how they are held in place.
Old 01-15-13, 10:29 PM
Qu0Cie
Qu0Cie's Avatar
All 3 should have tabs on them. Far left is the easiest one to pull out. The middle and far right I use a small flat head to push the tabs down to pull the plug out.
Old 01-16-13, 07:33 AM
Bankswood
Bankswood's Avatar
Yep ^^^^^^ what he said. I had the same problem. The clips are there take a small slotted screw driver and push down. The connector will separate easy.
Old 01-16-13, 08:20 AM
kmoore737
kmoore737's Avatar
Finally got the cluster out..Whew..does anyone have a link or know an easy way to get the speedometer motor out of the cluster?
Old 01-16-13, 12:55 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I think he got it!!!
Old 01-16-13, 03:22 PM
kmoore737
kmoore737's Avatar
Yep I got it out..... What a pain.
Deegee
SC- 1st Gen (1992-2000)
03-03-16 09:49 AM
AnthonyGS3
11-13-12 10:46 PM
Shnerez420
09-23-04 02:05 PM
Samuel
10-18-01 07:51 AM
Quick Reply: Instrument Cluster..removal easy...But the wires ????
