how to wire 97+ gauge cluster into pre97 sc300?
Excellent post hopefully I will be able to trace and find out why my check engine,temp,and all the lower warning lights don't work on my 98 sc300 can someone post a diagram that shows what each wore is for..thanks.
if you could pull and take pictures of the wiring and make some type of chart for the forum that would be amazing and really help me and everyone out who wants to do this swap.
The three plugs on my 93 dash harness
![](https://i31.photobucket.com/albums/c372/mattsmall8070/dsc03112_zps19dd21e1.jpg)
left connector 93
![](https://i31.photobucket.com/albums/c372/mattsmall8070/dsc03113_zps439ee8b1.jpg)
middle connector 93
![](https://i31.photobucket.com/albums/c372/mattsmall8070/dsc03114_zps66221ee9.jpg)
right connector 93
![](https://i31.photobucket.com/albums/c372/mattsmall8070/dsc03115_zps90a2b2c9.jpg)
the harness i have from the 97 sc300
![](https://i31.photobucket.com/albums/c372/mattsmall8070/dsc03116_zps3ec4518c.jpg)
white connector 97
![](https://i31.photobucket.com/albums/c372/mattsmall8070/dsc03117_zps72f8d0b5.jpg)
blue connector 97
![](https://i31.photobucket.com/albums/c372/mattsmall8070/dsc03118_zps362e1547.jpg)
grey connector 97
![](https://i31.photobucket.com/albums/c372/mattsmall8070/dsc03119_zps172fe1dc.jpg)
orange connector 97
![](https://i31.photobucket.com/albums/c372/mattsmall8070/dsc03120_zps96ab62e2.jpg)
any help putting this swap together would be amazing, thank you.
Another thing i noticed is the black trim pannel with the hour buttons has an extra ( mode ) button with the 97 pannel, the connector that clips in is the same but the wires arn't the same colors going into each pin location.
The 93 clock connector
![](https://i31.photobucket.com/albums/c372/mattsmall8070/dsc03121_zpsafc3e188.jpg)
the 97 clock connector
![](https://i31.photobucket.com/albums/c372/mattsmall8070/dsc03122_zpsb71e81b2.jpg)
i had a member email me someone's write up but not really sure what connectors are what on the list
![](https://i31.photobucket.com/albums/c372/mattsmall8070/gaugeclustersc300_zps61a75f8f.png)
gray = a
blue = b
white = c
orange = d
92-94 & 95-96 use the same plugs but different pinouts
97 & 98-00 use the same plugs but different pinouts
92-94 to 99-00
c13 to d13 - speed sensor input
c14 to c1 - speed sensor output
c15 to d14 - ground
left connector 93
middle connector 93
right connector 93
white connector 97
blue connector 97
grey connector 97
orange connector 97
gray = a
blue = b
white = c
orange = d
92-94 to 99-00
c15 to d14 - ground
