how to wire 97+ gauge cluster into pre97 sc300?
Does anyone have a write up or a pinout of the sc300 gauge clusters? I am in the process of wiring in a 97+ gauge cluster into my 93 sc300 and Google isn't coming up with alot of info.
With no luck I have traced and pin'd out three of the 4 connectors on the 97 cluster just have 23 pin orange connetor left to do
Tomorrow ill have my 93 cluster apart and I will try to make an easy guide for everyone to follow.
Keeper of the light
This would be most of the info you need. It has the diagrams as well as corrections to my diagram.
https://www.clublexus.com/forums/sc-...6-sc300-3.html
I have a 97 cluster in my 92. Everything works like stock....unfortunately, the cluster was already wired up before I bought the car, and I have not pulled it out to see how it was done. Mainly because I fear of what I'm going to find. The quality of other work on the car was nothing to brag about, so I'm scared to see what they did with wiring!
The three plugs on my 93 dash harness
![](http://i31.photobucket.com/albums/c372/mattsmall8070/DSC03112_zps19dd21e1.jpg)
Left connector 93
![](http://i31.photobucket.com/albums/c372/mattsmall8070/DSC03113_zps439ee8b1.jpg)
Middle connector 93
![](http://i31.photobucket.com/albums/c372/mattsmall8070/DSC03114_zps66221ee9.jpg)
Right connector 93
![](http://i31.photobucket.com/albums/c372/mattsmall8070/DSC03115_zps90a2b2c9.jpg)
The harness I have from the 97 sc300
![](http://i31.photobucket.com/albums/c372/mattsmall8070/DSC03116_zps3ec4518c.jpg)
White connector 97
![](http://i31.photobucket.com/albums/c372/mattsmall8070/DSC03117_zps72f8d0b5.jpg)
Blue connector 97
![](http://i31.photobucket.com/albums/c372/mattsmall8070/DSC03118_zps362e1547.jpg)
Grey connector 97
![](http://i31.photobucket.com/albums/c372/mattsmall8070/DSC03119_zps172fe1dc.jpg)
Orange connector 97
![](http://i31.photobucket.com/albums/c372/mattsmall8070/DSC03120_zps96ab62e2.jpg)
Any help putting this swap together would be amazing, thank you.
Another thing I noticed is the black trim pannel with the hour buttons has an extra ( mode ) button with the 97 pannel, the connector that clips in is the same but the wires arn't the same colors going into each pin location.
The 93 clock connector
![](http://i31.photobucket.com/albums/c372/mattsmall8070/DSC03121_zpsafc3e188.jpg)
The 97 clock connector
![](http://i31.photobucket.com/albums/c372/mattsmall8070/DSC03122_zpsb71e81b2.jpg)
I had a member email me someone's write up but not really sure what connectors are what on the list
![](http://i31.photobucket.com/albums/c372/mattsmall8070/gaugeclustersc300_zps61a75f8f.png)
gray = a
blue = b
white = c
orange = d
92-94 & 95-96 use the same plugs but different pinouts
97 & 98-00 use the same plugs but different pinouts
92-94 to 99-00
C13 to D13 - speed sensor input
C14 to C1 - speed sensor output
C15 to D14 - ground
