Anyone currently installing an r154
Old 02-14-13, 10:53 PM
rcchris7
rcchris7's Avatar
Default Anyone currently installing an r154
Alright.. I'm looking for a measurement since I don't have a motor to bolt mine too yet. Heres the jist of it. I plan on doing a shifter extension on the transmission itself to eliminate the swan shifter as seen here in vipsoarers thread https://www.clublexus.com/forums/per...arer-r154.html.
Now what I need to know is the length from where the transmission mates the bellhousing to the center of the shift boot.
just for a visual...
Old 02-15-13, 06:31 AM
99SC42
99SC42's Avatar
extend it 3" back and you good! I just post some pics on the other thread check it out.
Old 02-15-13, 06:46 AM
jwin
jwin's Avatar
I extended 3.5 inches. I used the stock mk3 shifter.
Old 02-15-13, 06:59 AM
99SC42
99SC42's Avatar
3.5" will also work , but 4" will hit the shifter bezel when you go in 2nd.
Old 02-15-13, 09:38 AM
rcchris7
rcchris7's Avatar
You guys are angels.. thank you very much. I've got some spare time and things are slow at my dads machine shop so I'm going to tackle this
Old 02-15-13, 10:31 AM
99SC42
99SC42's Avatar
Here are some more, and i will have some this week because i am extending another R154 shifter.
Attached Thumbnails Anyone currently installing an r154-img_20120320_181648.jpg   Anyone currently installing an r154-img_20120320_181731.jpg   Anyone currently installing an r154-img_20120320_181824.jpg   Anyone currently installing an r154-img_20120320_181829.jpg   Anyone currently installing an r154-img_20120320_181836.jpg
Old 02-15-13, 01:36 PM
snakehead
snakehead's Avatar
Stupid question ???
Why is it better to go with the extension rather than the swan shifter?
Old 02-15-13, 04:23 PM
alex425
alex425's Avatar
Does this need to be done to all r154 trannys?
Old 02-15-13, 08:52 PM
jwin
jwin's Avatar
Originally Posted by snakehead
Stupid question ???
The swan shifter won't get it back far enough unless you have the housing that is also extended which is the soarer housing before the tripod shifter.
Old 02-15-13, 08:54 PM
jwin
jwin's Avatar
No you don't have to extend all of the r154 tranny if you get a soarer r154 which is already the correct length back. Those are really pricey tranny though. I see them on ebay for 1500 bucks. You can get the Mk3 turbo r154 which will need to be extended to the correct place for an sc. Roughly 3-3.5 inches. When you extend the housing you can also run a short shifter later if you want. If you just cut the shifter and extend it back to the correct length as well. The choice is up to you. But for like 150-200 bucks i rather get it extended back.
1320VR4
SC400 / 300 Classifieds
09-01-17 12:36 AM
JesLet
04-07-15 02:55 PM
1JZPWRD
06-09-12 12:59 PM
Blk97SC300
72
05-29-09 01:44 PM
Quick Reply: Anyone currently installing an r154
