Bypass fp ecu
Hey guys I need some help today I bypassed my fuel pump ecu car ran fine for a couple of minutes then when I gave it s some throttle and let it come down to idle it shut off.after that it would not start.then stopped cranking over I started smelling raw fuel so I took number 1@2 spark plug out and they were full of fuel.when I crank the car with plugs off all the fuel shot out of cylinders.my car has bin dieing out randomly and wount start after so I did bypass but now this happen.
Yea the resonance why i did bypass was because when i was driving after about 10 min the car would shut off and would not start after i did the bypass my car turned on just fine but then i noticed the idle was to low after it warmed up so i adjusted idle but when i gave it a quick throttle and came back down to idle it shut off and would not start then that's when i pulled a plug an noticed it was full of fuel.I've used replaced air idle control and throttle passion sensor all so before i did the bypass.
speedf50
Performance & Maintenance
02-13-17 07:39 PM
acenase
04-16-09 04:15 AM
