Exhaust leak
Old 02-20-13, 05:26 PM
hihopes
hihopes's Avatar
Default Exhaust leak
Ive had an exhaust leak since I switched out my exhaust out. Ive got the stock headers/cat to a 3" HKS midpipe and Blitz catback. The leak is in between the flanges of the stock cat & midpipe.
When it was first put on, the shop said i needed a gasket and sealed it with RTV. That blew out quick so i ordered a few 3" exhaust gaskets. I figured this would solve my problem, but nope still leaked. I even tried doubling up on the 3" gasket, but there was still a leak. My last attempt was a recommendation from a friend, ultra copper sealant. Just like all the rest, this did not seal the leak very well.
Recently got my inspection done and the guy said i needed to get the leak fixed. I also noticed a decrease in mileage since it first blew out, so i just wanna fix the damn leak. Theres a gap between the flanges, and thats where the leak is coming from im assuming.
Anybody have this problem before, or have a solution? This is only temporary for a few months until I swap out my stock motor for a 1j, which means i wont have the stock cats so hopefully this problem wont exist.
Heres a pic of the flanges, incase it helps at all.
Old 02-20-13, 05:28 PM
1sWt2GS
1sWt2GS's Avatar
looks like its bent. u arent gonna be able to fix that. at least not with gaskets or sealant
Old 02-20-13, 05:44 PM
Candela
Candela's Avatar
You could probably bend it back, applying some heat
Old 02-20-13, 10:13 PM
hihopes
hihopes's Avatar
Is it relatively easy to bend it back? or worth going through the trouble since its only temporary?
Would a donut gasket have a chance at sealing it?
Old 02-21-13, 11:19 AM
sj408
sj408's Avatar
Yeah looks bent, id go to an exhaust shop and have em heat it and clamp it back straight.
Might also have a bit to do with going from stock collector size to 3 inch. Its like 2 1/4- 3 inch right?
Old 02-21-13, 07:50 PM
blk&blu*j
blk&blu*j's Avatar
Just have a muffler shop cut off the 2 bolt flange and put on a 3bolt flange with gasket all done.
Old 02-21-13, 08:22 PM
hihopes
hihopes's Avatar
damn, was hoping i wouldnt have to go back to a shop. Would it matter that its going to a bigger exhaust if everything lines up correctly besides the hole?
Whats the point in cutting off the current flanges to put 3 bolt flanges? The stock cats arent staying for long
Old 02-21-13, 08:48 PM
blk&blu*j
blk&blu*j's Avatar
2 bolt flanges are notorious for warping hence why domestics have been using 3 bolts for yrs.
Old 02-21-13, 08:59 PM
Candela
Candela's Avatar
^^^this is very true. and yet aftermarket exhaust parts for japanese cars are still usually 2 bolt.
Old 02-22-13, 09:19 PM
hihopes
hihopes's Avatar
alright maybe ill just get that done if i need to go to a shop anyway.
StuckInVA
07-15-13 01:51 PM
wvuguy
RX - 1st Gen (1999-2003)
10-29-09 06:22 AM
Sup2jzgte
03-27-09 04:28 AM
96sc3
10-04-04 10:35 AM
SLVRGS
GS - 1st Gen (1993-1997)
09-18-02 07:40 PM
Quick Reply: Exhaust leak
