Is this a soarer 1JZ?
I feel this is a soarer 1JZ, can anyone confirm this?
2nd This is with auto ecu, what will i need to make it work with m/t tranny?
3rd I am very confused about the water pump deal on the 1JZ, so can someone be nice and give me the part number for the part pump i'll need with this motor. Atleast i wont sound totally stupid when i call toyota up.
I have attached pictures for ya'll to see![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Thanks in advance!
Lokz
Thanks in advance!
Lokz
I can knock one question down for you.
You can use the auto ecu with a manual trans no problem, but its going to throw and CEL cause the ecu will be looking for the auto trans that isnt present.
As for the engine, IIRC the Soarer is a front sump oil pan, not rear. Someone correct me if Im wrong.
And again correct me if Im wrong, you want the water pump from a 2JZ-GTE.
Soarer is not front sump, I am 2 million percent sure about that. I know its a 2jz gte water pump too, but it would be nice to have a part number so i am 100% sure i have the correct thing
So then all you needed from this thread was the part number for the water pump...? And yes, I was backwards, Soarer is rear/mid sump.
Did you try searching for the part number for the water pump?
https://www.clublexus.com/forums/sho...mp+part+number
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Aristos/ Lexus GS front sump.
oh boy....![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
OK, that is 100% out of a soarer. The harness is a Soarer harness. You can tell be cause it has the exact same body plugs as an SC. Also, Soarers, unlike Chasers, have all 4 ECU plugs on the harness itself.
False. You will not have a CEL. You will not get a CEL from running a manual harness/transmission on an auto ECU with OBD-I. You only get it with OBD-II and since there is no such thing as OBD-II in Japan, you're golden.
Soarer is Definitely a rear sump pan. All TWO door Toyotas/Lexus are rear sump. All FOUR door Toyota/Lexus are front sump.
You need a USDM 2JZGTE water pump. It bolts right on. You'll need to get a GTE pulley for it as well.
-Cam, Tweak'd Performance
Thanks in advance!
Lokz
Thanks in advance!
Lokz
Thanks Dr TweaK for coming up and answering all my questions, i called them up and asked them to give me a leak down test video if all is good im buying this motor fo sho!
I dont know if anyone noticed but the wire i just circled there seems to be broken. I cant seem to see the other end of the wire with the plug with the pictures they sent me. I hope all is good
I dont know if anyone noticed but the wire i just circled there seems to be broken. I cant seem to see the other end of the wire with the plug with the pictures they sent me. I hope all is good![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
And just to make you warm and fuzzy I ran a Soarer auto ecu on my 1jz 5spd in my MK3 for yrs at 600+ hp on a piggy back with no issues.
And I sometimes forget USDM ****t.LOL
If you need one I have several dozen of them so no worries OP
