Vib and Noise
Vib and Noise
Hi All,
Been having a vib+ low rumble at 60-65 mph and up. I took it to my dealer(same who screwed up my clutch), they suggested replacing the bushings in the rear end, as the bushings are starting to show some minor wear. I took it to an indy shop and they suggest replacing the drive shaft. Now the indy shop pulled the shaft out and showed me a spot where the front U-joint has a spot or groove, where the movement isnt as smooth as the rest of the range of movement. I have been reading all the posts on drivetrains/driveshafts on here, and most of the descriptions seem to be in the 20-30 mph range. I tend to believe my indy shop more than the dealer, but was hoping some of you would have 2 cents on my deliema. as each job is going to be around a grand. thanks in advance for your input. Have a good one.
rickhughe9
02-07-11 01:42 AM
jgabem
09-10-10 08:11 PM
