need N/A 2jz cooling diagrams, OR help flushing heater core
having heat issues; im about 90% sure in this case that my heater is just clogged with rust and debris.
I did a coolant system flush by loosing the rust, then flushing the system with the block drain bolt loosened/ thermostat out, and one coolant hose removed at a time.
I forgot to turn the heater off ( habit ) during the flush, which means when all the coolant drained out, most of the debris and broken down rust remained in the heater core.
now the heater blows luke warm, though my coolant is topped off.
** i either need the routing diagram of the coolant system so i can figure out which hoes is BEFORE the heater core, and which hose is AFTER the heater core, so i can do a full flush...
or someone could just tell me which two they are. Thank you!
nikovdh
05-04-18 04:34 PM
