Desperate plea for help
Old 02-28-13, 12:50 AM
craignnem
craignnem's Avatar
Smile Desperate plea for help
My 92 Lexus SC400 has no rpm's, no acceleration whenever i step on the gas pedal. It Idles rough and has a strong gas oder. Can anyone please help?
Old 02-28-13, 05:53 AM
kmoore737
kmoore737's Avatar
Throwing any codes?
Old 02-28-13, 06:14 AM
chiken
chiken's Avatar
Bad coil? Only running on four cylinders? When you say no rpms do you mean on the tac?
Old 02-28-13, 07:19 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
If it's that bad, I'd check for a CEL as it probably will have one. Pull the code and go from there. What pops into my mind is an extremely clogged Catalytic converter(s). Pull code first...
Old 02-28-13, 07:34 AM
Ali SC3
Ali SC3's Avatar
probably an ignition issue, check codes.
Old 02-28-13, 11:57 AM
2jznosht
2jznosht's Avatar
Strong gas odor means its not being burned. I'd look at the ignition components as well. This may sound weird, but it could also be fuel pimp related.
mizak82
RX - 1st Gen (1999-2003)
02-01-21 06:22 PM
EJ255t
09-01-16 03:40 PM
GSJoe
10-22-14 06:45 PM
lexdud
08-16-10 05:24 PM
RedPhoenix
12
04-15-07 09:43 AM
Quick Reply: Desperate plea for help
