sc300 rear diff ?lsd
Old 12-29-15, 10:04 PM
  #31
3L4jzz31
3L4jzz31's Avatar
Bottom of post 2 for info saying that early sc430 diffs are swapable
http://www.supraforums.com/forum/sho...ferential-Info!
unfortunately no info on the gs430 diff.
Old 12-29-15, 10:44 PM
  #32
GTX580
GTX580's Avatar
I just swapped a gs400 3.26 diff behind the r154 / GE stock motor. Going to run this for a while the motor is being. In addition, I am running a ORC twin plate clutch, it is super grabby, should make this DD interesting.
Old 12-30-15, 11:32 AM
  #33
bpgt
bpgt's Avatar
I run a similar setup.
This transmission and differential gear combination with 295/35/19's in the rear, I'm cruising at 70 mph at about 2400 rpm's...should eek out decent mpg's for those that care about that. For those that are boosted, it gives the turbo room to work in each gear. (1st gear yields about 40 mphs at 6000 rpm's if i remember correctly).
Old 12-30-15, 11:53 PM
  #34
GTX580
GTX580's Avatar
I just took it for a drive, I am getting this grinding noise from the diff only when I am accelerating hard in 1st. Hopefully my diff isn't shot, I did change the fluid.
Old 12-31-15, 09:46 AM
  #35
scblackout
scblackout's Avatar
I went through the same thing with grinding only under hard first gear acceleration. Had the lsd professionally rebuilt with all new parts other than the lsd itself. Turns out that the 4 bolts that tie the drive shaft to the pumpkin are different lengths. There are 2 bolts that are about 1/2" longer than the other 2. What happens is when under load the drive shaft straightens out and the bolts and nuts were then impacting another part of the car causing the 'grinding' sound. Swapped them around and the problem was gone. The problem is there is no way to see this happening while the car is on a stand, but if you look closely at the nuts and bolts you may see that they are scarred from impact under load. If you see that, swap them around and the problem is solved. Simple fix that I hope solves your problem.
Old 12-31-15, 02:03 PM
  #36
GTX580
GTX580's Avatar
SCBlackOut, THANKS! I examined my diff again, the bolts are hitting the subframe. Need to change the bolts out.
Old 01-01-16, 10:36 AM
  #37
RXRodger
RXRodger's Avatar
Default This seems an appropriate place to post this
has anyone ran the numbers for shift points for the stock SC diff/W58 vs Supra Torsen diff/W58? Here is what I get:
(Edit: I am running 255/40-17's on 9" wheels for endurance racing. Measured ground to center for effective diameter)
Here is another thing about the Supra Torsen swap. It is mentioned in most of the threads on here that you may have to change the input yoke. I read that, but when I got my diff I looked at it and said hey, it looks like it is the same as mine. Should have measured, it is only ever so slightly different. When you attempt to bolt it up, the holes are off by maybe 1/2 or 1/3 of a hole. So measure closely before you put the diff in, don't be a dunce like me and get it in then realize it has to be changed. And finding a socket that fits the nut for the yoke, now that was another challenge. I should have wrote down what I used, seems like a 34mm wouldn't fit the nut, I ended up using an SAE socket, but it's been a while back and can't remember exactly.
Old 01-01-16, 11:11 PM
  #38
KahnBB6
KahnBB6's Avatar
Received 1,250 Likes on 870 Posts
^^ Yes. The Supra MKIV (and GS/Aristo) flanges are different than the SC/Soarer flanges.
The spacing difference should be 101mm (SC/Soarer) vs 111mm (MKIV/GS/Aristo), if I recall correctly.
It's a 35mm deep socket that is needed. I used a Powerbuilt 647079 35mm axle nut socket from Amazon.
To swap the SC socket onto the diff of your choice, it does require using a dial-type torque wrench, not a common click-type torque wrench. You'll want to follow the FSM procedure precisely to make sure the rear pinion isn't over torqued... which could upset the internal gear alignment and shimming made when setting up or rebuilding the differential.
Old 01-02-16, 09:39 AM
  #39
scblackout
scblackout's Avatar
It took us 3 rebuilds before we figured that out. After seeing how easy the mistake was to make I was sure that I couldn't be the only one who that would happen to. Glad to have helped out.
Old 08-14-17, 04:19 PM
  #40
Allday1
Allday1's Avatar
Originally Posted by victorhugo
Has anyone tried welding there differential ? Stuck with the 1leg tryna hit donuts n slide for a daily how good would it be if I did weld it? I have a 92 sc300 5 speed
My my 93 has a welded rear diff and it chews through tires like it's eating bacon I've been through two sets this year but like you said she'll slide everywhere
Old 08-14-17, 07:14 PM
  #41
RXRodger
RXRodger's Avatar
I am running a welded diff in my race car. It doesn't chew through tires like you describe, it just pushes entering turns worse than an open or lsd.
SCVito
05-06-22 06:13 PM
scblackout
06-28-15 12:18 AM
XxPainxX
SC- 1st Gen (1992-2000)
16
09-02-11 10:48 PM
93twintrbo
09-25-08 10:44 AM
FCDRIFT
01-08-06 09:34 PM
Quick Reply: sc300 rear diff ?lsd
