Turbo coolant fitting blew
Old 03-02-13, 08:12 PM
jmanhas
jmanhas's Avatar
Default Turbo coolant fitting blew
Hellur,
I was wondering if anyone could help me with this question. I just redid my turbo lines and i had to put a 90 degree bend in one and than put a bigger hose over it to my turbo fitting. I was revving my car to make sure the one fitting wasnt leaking and on the other side started squirting coolant. I am obviously going to replace the line but i was wondering could that have happened bcuz there it too much pressure built up where i have the bigger hose reduce to the smaller or could it be that the line was just weak. or could both be a cause. I also notice a kink in the line that burst. It is a braided steel line.
thanks in advance
Old 03-03-13, 12:40 PM
emoFTW
emoFTW's Avatar
More than likely it was just coincidence.
Old 03-03-13, 12:42 PM
emoFTW
emoFTW's Avatar
Wait I take that back. I just read that it's a steel braided line... You may another issue at hand...
zneubauer
08-08-17 11:17 AM
QWIKSTRIKE
04-02-14 10:10 AM
trevor10
06-10-09 10:05 AM
trevor10
06-07-09 02:48 PM
Kaiser
07-18-07 12:17 PM
Quick Reply: Turbo coolant fitting blew
