Distributor screws - do not remove
Old 03-03-13, 03:23 PM
tinman
tinman's Avatar
Default Distributor screws - do not remove
Ok, I'm a bone head. Let's get that out of the way first.
On the distributor for my 95 SC300 there are 2 screws under that cap that say "DO NOT REMOVE." Well, I removed them by accident. Anyonw know know what these do and if I can just put them back. I have moved the distributor since their removal. They were removed a while ago and I'm just now getting around to putting the SC back together.
Old 03-06-13, 08:13 PM
2jznosht
2jznosht's Avatar
I would put them back...om fairly certain I removed everything near the distributor when I was new to the car.
Old 03-06-13, 08:43 PM
1sWt2GS
1sWt2GS's Avatar
You should be fine. Just make sure the bolt is torqued to spec (I think that might be why it says do not remove)
schmoozer
12
12-23-09 12:29 AM
hapaboy
03-15-07 12:07 AM
Quick Reply: Distributor screws - do not remove
