Need help with car
Today when I started up my twin turbo soarer (in australia) and drove off it sounded a little different compared to normal.
It is hard to explain but when hitting 2000rpm + it sounded very "airey" almost like the air was escaping somewhere.
I am not sure if anyone has had the same problem or not.
Any help will be greatly appreciated.
Thanks
Thanks
1JZ Single SC400
Symptoms seem to be some sort of a vacuum leak to me. You can use carb cleaner or brake cleaner or WD40 just to if the idle goes up or down. Also try a smoke test if you have the means.
