Max hp on factory fuel lines?
Old 03-07-13, 04:40 PM
Blackgs301
Blackgs301's Avatar
Default Max hp on factory fuel lines?
Im wondering if 400-450whp is possible using the factory fuel lines. The car is a 92 sc300 na-t. I have a walbro 255lph fuel pump with an aeromotive FPR. I know that i saw a DIY upgrading the fuel line from the tank to the engine for an is300 but i cannot find that link. Any info would be great.
-Terry
Old 03-07-13, 04:58 PM
Candela
Candela's Avatar
Yes it is possible and safe, many guys on the forum have been doing so for years. Unless ur running some crazy multiple fuel pump super high pressure fuel system to match the air from a turbo that can yield ur engine probably 1000+ horsepower.
Old 03-07-13, 06:26 PM
Slow_Sc3
Slow_Sc3's Avatar
Get the fuel dampener bypass from DM and you will have enough fuel for mid 500 hp. My car with one 255, Fuel dampener bypass and 750cc injectors made 536@18psi on pump gas.. 93 sc300.
Old 03-08-13, 11:35 AM
Blackgs301
Blackgs301's Avatar
Ok cool thanks for the info. Ill definately delete that fuel pulsation dampner. Now i just gotta find that DIY link haha.
Old 03-08-13, 12:11 PM
GotRiceYo
GotRiceYo's Avatar
what turbo were you running when you made that power? other supporting mods? just curious cause id like to be around that power goal soon, just want to compare setup?
Old 03-09-13, 10:59 PM
Slow_Sc3
Slow_Sc3's Avatar
67mm turbo, hks cams, 4 inch intercooler, 750 cc injectors, aem ems.
nivekwb88
IS - 1st Gen (2001-2005)
05-29-15 07:10 PM
Biggu
03-01-11 07:56 PM
TinCan
Performance
08-18-08 09:05 AM
MyScRuNmIa
Maintenance
08-22-05 09:27 PM
Quick Reply: Max hp on factory fuel lines?
